FTR, zur Dokumentation:
Gateway-Einstellungen in den site.confs der verschiedenen Firmwares.
0.7.9~133:
"fastd_mesh_vpn" : {
"enabled" : true,
"groups" : {
"backbone" : {
"limit" : 1,
"peers" : {
"gw06" : {
"key" : "be56eb2cb9493f22b6e0cce4c7f8c838fd44e8c44c6983c58265bbe1c2cf04c0",
"remotes" : [
"\"gw06.4830.org\" port 10000"
"gw01" : {
"remotes" : [
"\"gw01-neu.4830.org\" port 10000"
"key" : "2ddba2fe0ed61615016cbbbd71ca1afcc7432dd8eb81c1e18806bcbb766b72b3"
"gw05" : {
"key" : "7f94344fa80d5ec144c14db366712a0cf34f420571cbe4e1025a3f23a88474cb",
"remotes" : [
"\"gw05.4830.org\" port 10000"
"gw03" : {
"key" : "40343e165e102f65513b5ddb2eb855289fc2e353af672fbe8924627acc2bf8ce",
"remotes" : [
"\"gw03-neu.4830.org\" port 10000"
"gw04" : {
"key" : "82532813585cba2538498df56869a57865fe8fa271c4eb61a9e4831310efbdcd",
"remotes" : [
"\"gw04-neu.4830.org\" port 10000"
"gw02" : {
"remotes" : [
"\"gw02-neu.4830.org\" port 10000"
"key" : "ee0902a7452d017cd154005e10944dcb278d648776988922d52b960e05d49780"
"event" : {
"peers" : {
"event01" : {
"key" : "21630f3eec4c38808b93947a5ac2f5eae39538b47e9225513bd2b2fa27c4593a",
"remotes" : [
"\"gw-event01.4830.org\" port 10000"
"event02" : {
"remotes" : [
"\"gw-event02.4830.org\" port 10000"
"key" : "e54a099a3967e2eae0a5e9afc4048adea0f5a7051bfc37616748797c76df77ac"
"test01" : {
"key" : "3d994652d67cc7a2b4d18cc852d450cd78bfdc50c2c3a8c6ed7df18591c033b3",
"remotes" : [
"\"gw-test01.4830.org\" port 10000"
"limit" : 1
"configurable" : true,
"mtu" : 1426,
"methods" : [
"salsa2012+umac"
1.0.0 - gut
mesh_vpn = {
-- mtu = 1312,
-- 1374 should work with anything that can transport 1460 Bytes (DS-Lite MTU) for batman v14 and v15, IPv4 and IPv6.
mtu = 1426,
-- mtu = 1374,
fastd = {
-- Refer to http://fastd.readthedocs.org/en/latest/ to better understand
-- what these options do.
methods = {'salsa2012+umac'},
-- syslog_level = 'warn',
groups = {
backbone = {
-- specifies how many servers are contacted by a client simultanously
limit = 1,
-- list all available vpn servers
peers = {
gw11 = {
key = '2ddba2fe0ed61615016cbbbd71ca1afcc7432dd8eb81c1e18806bcbb766b72b3',
-- This is a list, so you might add multiple entries.
-- You can also omit the ipv4 to allow both connection via ipv4 and ipv6
remotes = {'ipv4 "gw11.4830.org" port 10000'},
gw10x = {
key = '82532813585cba2538498df56869a57865fe8fa271c4eb61a9e4831310efbdcd',
remotes = {'ipv4 "gw10a.4830.org" port 10000',
'ipv4 "gw10b.4830.org" port 10000',
'ipv4 "gw10c.4830.org" port 10000' },
„Historisches Mapping“ (ffgt-ip.txt):
| GW | Public Key |
| gw01 | 2ddba2fe0ed61615016cbbbd71ca1afcc7432dd8eb81c1e18806bcbb766b72b3 |
| gw02 | ee0902a7452d017cd154005e10944dcb278d648776988922d52b960e05d49780 |
| gw03 | 40343e165e102f65513b5ddb2eb855289fc2e353af672fbe8924627acc2bf8ce |
| gw04 | 82532813585cba2538498df56869a57865fe8fa271c4eb61a9e4831310efbdcd |
| gw05 | 7f94344fa80d5ec144c14db366712a0cf34f420571cbe4e1025a3f23a88474cb |
| gw06 | be56eb2cb9493f22b6e0cce4c7f8c838fd44e8c44c6983c58265bbe1c2cf04c0 |
| local | c86edcd352c426c4e33033fc6592537f50ac494d2ce0b380f23953395393e15b |
| stats | fcf10dd1caba177640854ca78a4e6b329af08e9050911288702f08b3ec68841c |
| event01 | 21630f3eec4c38808b93947a5ac2f5eae39538b47e9225513bd2b2fa27c4593a |
| event02 | e54a099a3967e2eae0a5e9afc4048adea0f5a7051bfc37616748797c76df77ac |
| westa01 | 0f7b8b0791ed68ef54f633362a2358a95793fa728085745b2329fb7c6635f693 |
| test01 | 3d994652d67cc7a2b4d18cc852d450cd78bfdc50c2c3a8c6ed7df18591c033b3 |
| test02 | f28c197d340a990c21198c829cdf383d1c837c72379abaa7486870e749dadc6d |
| map | b1f9a16bafbe9498c51d050dd4533e5a2626a5eb219104449cf3fc27918458b1 |
| gw20 | 62aaaca590def565fc32337f40e910e1e0d8e814ae01213dd8a080595e316015 |
| gw21 | 1b2eec78bddc5ee108eda6dd082ce1f1acf474970b8fefe7cfb542934af75a7b |
| gw22 | 85072a043940d155c269d70ff68ca03c2bf086f2b1b2c9a547730cbeea6387d9 |
| gw23 | 4b569e02d5ba8d29409d88f62646d9e4c1a976d654aff4b13236691b2075241c |
| gw30 | 0afa6fe4ccc8b96c6d56368b18bf99e33925aaaf745cef1cb18a12007ab38762 |
| gw31 | b802af6a771194aec13ef766ebe0ff734b74309067f8ee0e60dce14d3f714096 |
| gw32 | 3490e065510ed308cb22f4bff7bf3682c045be29105c5cd478bfe83524876f25 |
| gw33 | 8d818c07a0334ecd34512bede238a3b068b69347b1ac347e417815f83f743270 |
| gw34 | 45600b0e28331ac4a89b5b0cc129ae70239bba8fea7034745f89eb74d953a472 |
